Hello guys, i wanted to build a pc, can you tell me if this is a good build for gaming ? or i should choose i9 9900k
instead ? below is the build i am thinking of doing.
AMD Ryzen 3900x 3.8 GHz 12 Core Processor
Gigabyte x570 GAMING X ATX AM4 Motherboard
G.Skill Trident Z RGB 32 GB (4x8 GB) DDR4 - 3466 Memory
Zotac GeForce RTX 2060 SUPER 8 GB Video Card
SeaSonic FOCUS Plus Gold 550 W 80 PLUS Gold Power supply
https://linustechtips.com/topic/1163799-pc-build-help/
Just now, Flokikz77 said:
you copied the URL instead of the permalink, you should fix that. also
if it's a gaming PC, the 9900K is terrible value.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363880
if it will mainly be used for gaming i would switch to 16gb ram and go a 3600x or 3700x and use the extra money to go better with the gpu and go to a bigger psu
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363922
14 minutes ago, Flokikz77 said:
ohh ok i'm new to these things xD i did it differently now can you check ?
It's not a permalink so it's still not the whole parts list802490622_Screenshot_20200310-214031_Chrome2.jpg.c19ff97ebe44cd3e3f942a01c0f41527.jpg
What is the main use for this PC? You have a 12 core CPU and 32GB of ram with a relatively weak GPU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363927
What is the main use for this PC? You have an 8 core CPU and 32GB of ram with a relatively weak GPU.
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363947
-snip-
If your gaming, get a 3600 and a 2080
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363951
8 minutes ago, Flokikz77 said:
it's a really bad build for gaming, you have too much ram and too many cores. If you spend less money there, you can get an awesome GPU
16 minutes ago, Flokikz77 said:
Country is Portugal and budget is in between 1300 1500 euros
since you didn't include any SSDs or a case, I'll leave extra room for you to pick those
You could drop to the Ryzen 5 3600 if you needed to save more money.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363956
thanks bro, the case and SSDs i already have from my other pc.
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363983
Then you're basically set with this parts list, but you have the budget to consider a higher end motherboard https://pt.pcpartpicker.com/product/McfFf7/asus-prime-x570-p-atx-am4-motherboard-prime-x570-p
Primary PC:
PSU tier list
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13363988
thanks for the help, my old pc is too weak for new games so i want to make update, is not that bad but i like to play on ultra settings
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13364015
I just notice on Compatibility notes says: The Asus PRIME X570-P ATX AM4 Motherboard has an additional 4-pin ATX power connector but the BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply does not. This connector is used to supply additional 12V current to the motherboard. While the system will likely still run without it, higher current demands such as extreme overclocking or large video card current draws may require it.
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13364768
The extra connectors won't make a difference for the average user. It's for extreme overclockers
Primary PC:
PSU tier list
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13364771
On the build you made for me if in the future i want to make some upgrades witch parts i should upgrade ? ?
Really depends on what performance you're after. You might find a CPU upgrade necessary, or a GPU upgrade
Primary PC:
PSU tier list
https://linustechtips.com/topic/1163799-pc-build-help/#findComment-13364841
