Unraid zfs help
Go to solution Solved by Jarsky,
Just now, AbusedDoughBoy said:
yes, so if i add 1tb of data it will end up showing 82.1tb free of 82.1tb. TBH it's not a huge deal but if i can fix it i would like to and ill get to learn something.
yeah change your path to
path = /mnt/dumpster/dump
then create seperate SMB mappings for /mnt/dumpster/vms and /mnt/dumpster/docker if you require those.
After many many many hours of reading and learning i finally got all of my 60 hdds into a pool and created an smb share. Now the issue is and what i need help with is in windows the used and total size of the share doesn't show up correctly. Thanks for the help in advance!
https://linustechtips.com/topic/1163497-unraid-zfs-help/
Well ZFS isn't supported on UnRAID.....
But I assume your datasets show correctly on UnRAID? e.g if you run zfs list, the dataset's show properly there?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1163497-unraid-zfs-help/#findComment-13361288
I know it's not officially supported but there is a plugin you can add on. All the data sets work and i have access to it over the network, only issue i have is it doesn't show used and total size of the drive correctly. Whenever i add anything to it all it does is shrink and doesn't show how much is used or the total space.
https://linustechtips.com/topic/1163497-unraid-zfs-help/#findComment-13361309
can you show your zfs list, df -h /, and cat /etc/samba/smb.cnf (or your samba config wherever you created the config)
also are you using SMB1 in Windows? e.g did you have to enable this to get sharing working?
https://linustechtips.com/topic/1163497-unraid-zfs-help/#findComment-13361333
This looks fine.....so if you add files to dumpster, then that '83.1TB free of 83.1TB' the entire value changes?
Edit: actually looks like you aren't mapping to your dataset's, you should have 'dumpster' as /mnt/dumpster/dump
https://linustechtips.com/topic/1163497-unraid-zfs-help/#findComment-13361378
https://linustechtips.com/topic/1163497-unraid-zfs-help/#findComment-13361383
