Hi,
First of all sorry for my English, I'm from Argentina.
Now going to the problem that came up.
Not long ago I installed a program, "Autodesk Inventor 2020", when I was at the last stage of the installation, I noticed that the bios LEDs began to flash (like a "bootloop"), it went from the main BIOS LED to the LED of the backup BIOS.
Following this I turned off the PC, then the PSU and drained the power of it. When the PC was turned on again, it started without any "Bootloop" seen with the BIOS LEDs, the only thing I noticed is that the motherboard's LED display went from marking me "A0" to "24". Currently the system seems to work without problems, I only notice that difference.
-Is that a problem with my PC?
-Should I be worried?
-Is there a way to fix this?
Regards,
I am looking forward to your response.
My PC components are:
-Ryzen 7 1700
-Gigabyte AX370-Gaming K7
-RX 580 8gb Sapphire LE
-16gb ram (2x8 3200mhz) T-FORCE DELTA
-Stock cooler
-120 ssd storage, 1tb hdd storage, 250g hdd storage.
https://linustechtips.com/topic/1163412-i-need-help/
your font causes a formatting issue, copying here so people can see it
Hi,
Regards,
-Ryzen 7 1700
-Stock cooler
BIOS codes changing during operation is fairly normal, you shouldn't worry.
Edited by Fasauceome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1163412-i-need-help/#findComment-13360534
