Please help me choose a GPU
Go to solution Solved by Stormseeker9,
20 minutes ago, Wintersoulja said:
Hey guys I'm pretty new to the computer assembly world as the last computer i had my friend built for me 8 years ago.  After spending some time learning from this wonderful tech community I'm close to finishing a new build. After saving every penny I could for the last 4 months or so I was able to come away with ryzen 5 3600, b450 tomahawk max mb, 16gigs 3600 speed ram, 600w psu, 250g ssd plus 2 tb hard drive, and chose the phanteks p400a case. The last thing I must save for is the gpu.  As I am now I couldnt see myself being able to buy anything over 400 bucks.  Could you all give me advice as to what card to look into. Do I go for a 400 dollar card if so which ones to look at? My other thought is going 300 dollar card and maybe using that other 100 to help start saving for a new panel. Any help is appreciated sorry for the wordy post.
What psu did you choose?
as for GPU perhaps this one
PCPartPicker Part List
Type Item Price
Video Card Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card $409.99 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total $409.99
  Generated by PCPartPicker 2020-03-03 01:11 EST-0500
https://linustechtips.com/topic/1161317-please-help-me-choose-a-gpu/
Type Item Price
  Total $409.99
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Type Item Price
  Total $409.99
I chose the EVGA 600 BQ 80 plus bronze
1 minute ago, Wintersoulja said:
United States
If you're gaming on 1440p or higher, choose either the RTX 2070 Super or the RX 5700XT.
If you're on 1080p with no plans to go 1440p or 4K in the near future (a year or two), go with an RX 5600XT, a GTX 1660 Super or an RTX 2060.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Echo what others said. Definitely check out that 5700XT since its $400 and best bang for buck. And apparently, AMD fixed most of the problems with the drivers, so you should be fine. Either way, good luck with your choice!
Leonidas Specs: Ryzen 7 5800X3D | AMD 6800 XT Midnight Black | MSI B550 Gaming Plus | Corsair Dominator CL16 3200 MHz  4x8 32GB | be quiet! Silent Base 802
Maximus Specs: Ryzen 7 3700x | AMD 6700 XT Power Color Fighter | Asrock B550M-Itx/AC | Corsair Vengeance CL 16 3200 MHz 2x8 16 GB | Fractal Ridge Case (HTPC)
for sure i would look at the RX 5700 series or a RTX series card (2060 or 2070) with the RTX 2070 Super been the best value vs performance GPU right now.
As you have a AMD CPU it might be best to get the highest performing GPU from AMD in your price range.
do you have any preference to manufactures? colours, number of fans etc?
if you like Nvidia, EVGA do some good deals. Asus are nice but a little more cost.  then there are other options and different manufactures.
usually you get what you pay for.
12 minutes ago, Frayia said:
...with the RTX 2070 Super been the best value vs performance GPU right now.
What? Basically every GPU below $500 are better value than the 2070S, it is the best GPU under $500, but in no way the best value, plus it is out of the budget of the OP.
Why? even though under $400 i would probably get the 5700, that have nothing to do with what CPU is in the system, it's not like Nvidia GPUs are going to perform worse than AMD ones in a AMD system.
That’s a horrible unit to be fair. Do you have a Corsair RMx or TXm or if On tight budget a Corsair CX available to you? 550W will be plenty.
i would opt for a 5700XT if you want 1440P. If it’s only 1080P a 5700 will do and will have some more left in the tank if you ever wish to upgrade your monitor
Ty for your time and input!
Thank you! I'll take a look at that card
