Ram Problems
Solved by boggy77,
3 minutes ago, William23r said:A 2600x and B450 Gigabyte aourus m
so when you go into bios and enable xmp, manually change dram voltage to 1.35 and also change soc voltage to 1.05. this should allow it to run a bit more stable. ryzen 2000 series have some problem with tthe memory controllers and sometimes struggle to run 3200 without some voltage increase.
