Hello everyone,
This will be my first time building a pc. I was inspired after seeing LTT videos. I am a sucker for RGB ambient lighting so naturally I want RGB lol.
I’m hoping somebody could tell me if the parts I have picked out are compatible and will work the way that I want.
1.I want all of the RGB components (fans, gpu, aio, motherboard, ram, etc) to be able to sync together painlessly so they will all match. I want to be able to have the rgb lights light up in a way that shows it traveling from one component to the next, and sometimes just have them all be able to slowly cycle through all of the colors. And of course one static color if I choose.
I also have a Steelseries apex rgb gaming keyboard, and steelseries rgb prism XL mouse pad that I have connected to my macbook pro that I also want to be able to use with my pc build and have their rgbs synced with the pc components.
2. I want to be able to power on the PC by using the switch on a power strip that it will be plugged into as the case will be a bit out of reach where I plan to put it. I have read that there is usually a setting in the motherboard BIOS to do this but I don’t know if this motherboard has that.
3. I want to be able to connect my PC to a USB C monitor at some point as I currently have a Macbook Pro for my video and photo editing that connects via USB C hub and I will eventually have a USB C monitor. I know the GPU I picked has a thunderbolt 3 port but the description isn’t very clear on if it can be used by itself?
Thank you in advance!
Build:
Case: Corsair Crystal Series 280X RGB CC-9011135-WW Black Steel / Plastic / Tempered Glass Micro-ATX Case Computer Case
Motherboard: MSI MPG Z390M GAMING EDGE AC LGA 1151 (300 Series) Intel Z390 HDMI SATA 6Gb/s USB 3.1 Micro ATX Intel Motherboard
Processor: Intel Core i7-9700K Coffee Lake 8-Core 3.6 GHz (4.9 GHz Turbo) LGA 1151 (300 Series) 95W BX80684I79700K Desktop Processor Intel UHD Graphics 630
RAM: G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) Desktop Memory Model F4-3600C16D-16GTZRC
GPU: GIGABYTE AORUS GeForce RTX 2070 Super 8G Graphics Card, WINDFORCE Stack, 8GB 256-Bit GDDR6, GV-N207SAORUS-8GC Video Card
SSD: SAMSUNG 970 EVO M.2 2280 1TB PCIe Gen3. X4, NVMe 1.3 64L V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-V7E1T0BW
AIO: CORSAIR Hydro Series, H115i RGB PLATINUM, 280mm, 2 x ML PRO 140mm RGB PWM Fans, Advanced RGB Lighting & Fan Control w/ Software, Liquid CPU Cooler. CW-9060038-WW. Support: Intel 2066, AMD AM4, TR4.
RGB Fans: Corsair LL Series CO-9050072-WW LL120 RGB, 120mm Dual Light Loop RGB LED PWM Fan, 3 Fan Pack with Lighting Node PRO
https://linustechtips.com/topic/1160797-first-time-build-need-help/
No PSU?
I would go for the Corsair ML PRO 120 RGB, by far better fans.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
2 hours ago, Constantin said:
No PSU?
I stopped before picking a PSU because I read that you can’t get RGB from different manufacturers to sync together. So it kind of stopped me in my tracks lol.
Do they fit in the 280X case?
Of course!
31 minutes ago, Msalve said:
Thank you!
Do you happen to know any answers to my other questions? Seems like nobody wants to answer my post lol
i think no one is answering because no one figured out how to make all the rgb work together to be honest
