First Watercooling loop
4 hours ago, buchi18 said:Hey guys i am think about making my first costum watercooling loop.
I only want to cool my cpu cause for my gpu there are only ugly blocks and the temps leave enough headroom even after overclocking.
I have enough room for a 240mm 40 mm thick rad and fans.
Since its my first loop i will go for soft tubing.
Now i wanted to knoe what you guys think about the fluidgaming stuff from ek.
The price seems to good to be true i know that all is aluminum, so adding something to the loop would be hard to find parts.
But i could sell it to friend of mine if a want to build another loop.
Or is there an option of cooper stuff that isnt like 5 times the price?
I have an EK Fluid Gaming loop, and I really like it. Temps are at most 1-2 degrees off from copper, and assembly wasn't too bad. The parts are all very high quality for the price, as you'd expect from EK.
The one suggestion I would have would be to get yourself a 90-degree pump bracket- the flat bracket that comes with the kit only fits cases with no lower shroud and bottom fan mounts, which is pretty rare nowadays. With a 90-degree bracket you simply mount it to your front radiator.
