yes it can be reused i would highly suggest putting new thermal paste on it though
Main Pc: CPU: ryzen 5 5600x  Motherboard: Msi b450 gaming plus max  RAM: 32gb corsair vengeance ddr4 3200mhz ram  GPU: Nvidia rtx 2070 SUPER 8gb Case:  cooler master td500   PSU: corsair 750watt bronze80+  Cooling: Kraken x53 aio Storagewdblack snd750,3tb wd blue hdd
2nd Pc: CPU: ryzen 5 3600 Motherboard: Gigabyte AB350M-Gaming 3  RAM: 16gb 3000mhz gskill Aegis  GPU: Nvidia gtx 1650super 4gb  Case: Cooler Master MasterBox MB311L ARGB Airflow PSU: corsair cx 550watt 80+ bronze Cooling: Vetroo V5 CPU Air Cooler Storage: adata su635 240gb ssd, seagate 750gb 7200rpm hdd
3rd pc CPU: i7 2600 Motherboard: asus H61M-E  RAM: 16 gb ddr3 1333mhz GPU: nvidia gtx 1060 3gb Case: thermaltake versa h18 PSU: evga 450watt 80+ bronze Cooling: Cooler Master I70C (Copper Core) Mini CPU Cooler Storage: crucial mx 500 500gb ssd, wd blue 1tb 7200rpm hdd
https://linustechtips.com/topic/1160165-cpu-overheating/#findComment-13333155
A CPU overheating doesn't usually kill it right away, it may either cause thermal throttling or thermal shutdown but it's supposed to have safety features to protect itself.
just make sure you don't consistently overheat it
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1160165-cpu-overheating/#findComment-13333156
Well to give a short history of what happened...this tower belongs to my nephew...he built a few years back and it was idling close to 100° after he heard a popping sound from the tower. He didnt bother to fix but opted to build a new rig. Mind you he was using the old tower for about a month before he had the new rig ready to go so i assume the overheating happened several timesHe is offering the tower to me for 250 as is since he can't guarantee it wont crap out within a few days or mi utez for that matter. My thought was to build a newrig using only the cpu and replace everything else
https://linustechtips.com/topic/1160165-cpu-overheating/#findComment-13333190
If something went pop, it was probably the power supply or something, not the CPU. Idling close to 100 degrees means stop using the PC and fix it, I hope he knows that before he ruins something else.
Either way, I bet there's a good chance the CPU is still good. At the very least, the ram and hard drive/SSD are still good, and the GPU if there was one, so tossing a new PSU (and if needed, mobo) into the same case is a good call.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1160165-cpu-overheating/#findComment-13333197
This guys nephew:
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1160165-cpu-overheating/#findComment-13333203
i7-8700K is like what 2.5 years old?
And your nephew had it for several years and overheats to 100C?
Anyway, modern CPUs will shutdown before it gets hot enough for any critical damage.
Just open the computer, clean it, reapply thermal paste and maybe change the cooler (Noctua recommended).
i9-10940X @5.40GHz (OC record):  https://valid.x86.fr/5jiapc
https://linustechtips.com/topic/1160165-cpu-overheating/#findComment-13333220
Thank you for the info
https://linustechtips.com/topic/1160165-cpu-overheating/#findComment-13333224
