Hey everyone! I can provide pictures if needed, but I'm currently planning to mod a Dell XPS 200 case. It's badass, and I've got some cool plans for water cooling and the such, but I'm running into some issues. (A side issue, does anyone know a different PSU that'd fit in the case? If so that'd be awesome) but anyway- the front io has a board with a cable that connected to the Dell motherboard that came with it- it has 39 pins and is made by foxconn (look up 39 pin Dell io on eBay and you'll probably see it) does anyone know how I could modify this to be able to use a normal boards io?
https://linustechtips.com/topic/1159580-pin-modification-help-needed/
