Ok, this is a slightly complicated question but I'll do my best to cover it. First, I have an Asus Strix 1080Ti card. That card takes two individual 8-pin power connections from the PSU. My PSU is a corsair AX1200i. It is a modular PSU and I have a custom braided red cabling kit compatible with the PSU. Here's the rub. My power cable for my GPU, is a single cable running from the power supply, to the GPU, that first connects into the GPU for the first 8, and then immediately splits off into another 8-pin split from that so I literally have to make a loop of cabling from the first connection to hit the second, and it leaves a very awkward and messy lump of cabling at the power connection to my GPU. I've seen very clean builds with braided cabling from the PSU where the cabling to the GPU appears to be two individual cables. Also in many GPU builds I see a card with power that is an 8-pin and then a 6-pin instead of 8 and 8. Sorry that the images aren't that great. The white cabling is an image I found. It clearly has a gpu power cable with 6 and 8. The red cabling is my GPU cabling. It's a single cable from the PSU that to be connected to the GPU has to be looped and folded and couldn't possible be cleaned up with cable combs. So, to the point, I'm trying to figure out what I'm missing to be able to do my GPU cabling in a way that's much more clean that this, and hoping someone can help. Sorry about the long-winded explanation.
As always, I appreciate any time and wisdom that you can afford me.
Thanks!
Also, for the record, this is in fact a sneak peek of my build but despite how messy these peeks look I fully intend to organize my internal cabling to perfection (if I can figure out how to do that).
Everything I've done with my computer build so far is well-documented at:
My Thermaltake Home Profile
SPECKS!! ...specs:
Case: Thermaltake W200
Motherboard: MSI MEG Z390 Godlike
CPU: i9-9900KS
CPU Cooler: Corsair H150i RGB
RAM: G.SKILL TridentZ DDR4-3200 32GB
GPU: Asus Strix 1080Ti
PSU: Corsair Ax1200i
System Drive: Samsung 970 Pro M.2 SSD 1TB
Storage: Samsung 970 Pro M.2 SSD 1TB x4
Display: Asus PG348Q 3440x1440 100Hz
Sound: SoundBlaster Katana X
Network: CAT8 Cabling & Wifi6
Keyboard and Mouse: Redragon K556 RGB & Redragon M711 Cobra
Case Fans: Primarily Noctua 140mm 3000RPM
Case Fan Controller: Lamptron FC-8 8 Channel
Cosmetic Light Appeal: Remote Controlled Light Bars x2
https://linustechtips.com/topic/1159313-asus-strix-gpu-power-cabling-question/
Those are done with 2 single connection (i.e. one connector on each end) PCIe 8pin custom cables bonded together with PSU cable combs.
Desktop benching:
Run two individual sets of cables, like so:
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Oh sweet! I see now! Yeah that will make it look a lot cleaner. Thanks guys!
SPECKS!! ...specs:
CPU: i9-9900KS
