So I'm looking for a potential upgrade.
What I mean is that while streaming, my both my game and stream drop A LOT of frames. I've been trying to stream Overwatch at 720 60fps while I play at 1080 144hz.
I've been able to stream Modern Warfare before with barely no problems, so what I'm thinking that there's something funky going on with OBS
But anyways, I don't know which to go for. Either the Ryzen 5 2600, Ryzen 7 2700, or the X variant of them? Or will the 2700 /X be overkill?
Will there be any limitations on the 2600?
Specs:
CPU
Ryzen 5 2400G
Motherboard
Gigabyte GA AB350M Gaming 3 Micro ATX
RAM
G.SKILL Ripjaws V Series 16GB (2 x 8GB) F4-3600C19D-16GVRB
GPU
XFX RX 580 GTS Black Edition 1425MHz OC+
PSU
Corsair CXM 550W 80+ Bronze ATX
OBS skipped frames:
https://linustechtips.com/topic/1158989-cpu-upgrade-for-streamingrecordingedit/
get a 2700 that should help a lot
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
2700 wouldn't be overkill, but is the 3600 in budget?
3 minutes ago, Syaoran said:
No, I don't so
Also, I edited the post @GDRRiley @Slottr
"Will there be any limitations on the 2600?"
it is an extra 20$ just step up to the 2700 unless you really need it
No, I don't so
You'd be able to do fine with the 2600 for sure, but for this situation- the 2700 would benefit you fairly well
If you can afford it, the 2700 is a steal. If not, and you're more comfortable spending as little as possible then the 2600 (or 1600 AF for even cheaper)
