I am not tech savy at all, I bought a rtx 2070 graphics card, but still only get average of 60 fps in Overwatch. All my settings are low, I think it's something with the computer. I bought it from my cousin so I don't know all the parts.
CPU: AMD FX-8350
Motherboard: ASRock 970 Extreme3
If I need to buy a new motherboard and CPU, any recommendations that won't break my wallet? And would I have to buy anything else to go with those?
https://linustechtips.com/topic/1158276-i-need-help/
CPU bottleneck would be my guess.
To upgrade, get a 1600 AF or 2600 + a B450 Pro 4 and 16GB of 3000mhz (or faster) memory.
What power supply do you have?
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13317429
I'm honestly not sure.. I downloaded CPU-Z just so I could find out my motherboard. Where could I find the kind without taking it apart?
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13317435
Won't be able to. If you pop the side panel off you can glance inside though and take a look quick.
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13317440
12 minutes ago, Bon said:
RM850
I'd blame cpu bottleneck then. That's a good unit.
How are temperatures on the cpu and gpu?
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13317471
CPU: AMD FX-8350
Yeah, I'd also say your CPU is the issue. You need to upgrade.
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13317534
I was looking at the motherboard and some people said you should just spend a little more for a better board, is there a different recommendation for ~$100
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13317555
The pro4 is a perfectly fine board, especially for mid tier chips like those.
If you feel like you NEED a better board, the tomahawk max is around 115 USD
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13317559
  • 4 weeks later...
I changed the motherboard and the CPU and got the ram. But now when I turn the power on it just resets every 20 seconds
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13387894
Just now, Bon said:
I don’t know if it’s worth noting but the ram doesn’t fit into slot A1 so I put it in B1 and B2
What do you mean doesn't fit?
have you tried anything to troubleshoot?
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13387902
The heat sink or whatever fan that’s on the CPU is too close to the slot so you can’t set the ram straight into it. What things would I have to do to troubleshoot?
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13387908
You'll probably only use slots A2 and B2- stick them in there. If it doesn't boot, try with one stick in various spots.
https://linustechtips.com/topic/1158276-i-need-help/#findComment-13387912
