So I built a new pc with some parts moved in from the old one like the two Thermaltake LED 120mm fans I had and the gpu/hdds.
Currently using a r5 3600, gigabyte gtx 1060 aorus with a NZXT M22.
It is setup with the Aio top front, and the fans in slots 1,2,3 with 1,2 as intakes and 3 as exhaust.
Now the cpu runs at 55C which is fine but the gpu goes upto 72 which is nothing alarming but I was wondering if I could do anything to the fan setup to improve it. Perhaps change them as intake/exhaust might improve the airflow to the gpu?
Thanks in advance.
https://linustechtips.com/topic/1158040-phanteks-p350x-fan-setup-help/
I would flip the top fan to exhaust to aid the removal of hot air quicker.
Or
Move the AIO to rear exhaust, flip the top for exhaust and have 2 120s as intake.
Ideal setup for the P350x imo is 2 x 140s front intake and 2 x 120s rear and top for exhaust.
