Browser, version and OS: win 10
Steps to reproduce/what were you doing before it happened?
I was cleaning off some thermal paste from the CPU because it wasn't booting before but all the fans spun before
What happened?
When everything was cleaned up and I put the CPU back in, when I power it on nothing happens there is just a ringing sound coming from the psu
What did you expect to happen?
For it to at least boot like normal
Link to a page where it happened, if applicable:
Screenshots of the issue, if applicable:
Any other relevant details:
There was only a very minute amount of thermal paste on the pins, I hate amd CPU pins
If it's a cloudflare error, what was the ray ID from the bottom of the error page?
https://linustechtips.com/topic/1157689-pc-wont-power-on/
1 hour ago, Abyssal Radon said:
Did you make sure everything is connected, sometimes when you work on a computer you can accidentally loosen/disconnect power connectors to the motherboard or PSU (if partial/fully modular). Does it post?
Everything is connected, it might be a bad psu because I was having problems before I got a new mobo and cpu
https://linustechtips.com/topic/1157689-pc-wont-power-on/#findComment-13313226
I just hear a ringing noise coming from the psu when I plug it in, occasionally when I unplug the power cable the fan on the CPU moves slightly
https://linustechtips.com/topic/1157689-pc-wont-power-on/#findComment-13313228
