Hello everyone,
I'm currently building a costum desk pc and I had to get two PSU's that were both 300 watts as they were the thinnest ones I could find. However, they do not have an 8pin and 6pin cable for my GTX 980. Are there any adapters i could use to get an 8pin and 6pin cable for my GPU or will i need to buy a new PSU?
The two PSU are these ones:
http://www.gamemaxpc.com/product/showproduct.php?id=260
Many thanks for everything
https://linustechtips.com/topic/1157176-psu-cable-adapters/
you will need to get a new PSU
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1157176-psu-cable-adapters/#findComment-13308652
1 hour ago, LukeSavenije said:
you have a huge risk of voltage drops and very hot cables with adapters like this, i really wouldn't recommend it
especially since something like molex was never designed for these kinds of things
Ah ok fair enough, probably will look for another PSU then, I did think it did seem a tad sketchy but wasnt sure if anyone had any experience with them.
Thanks for the help
https://linustechtips.com/topic/1157176-psu-cable-adapters/#findComment-13308953
3 minutes ago, maxzug2 said:
Thanks for SFX power supply suggestion, I found one that should hopefully work. Many thanks
Which SFX power supply did you find?
One thing to keep in mind is the length of the cables with SFX power supplies. They're often made for smaller ITX cases and have shorter than normal cables. Make sure the length of the cables will work with the layout of the desk PC.
https://linustechtips.com/topic/1157176-psu-cable-adapters/#findComment-13308974
