Ryzen Master issue
Go to solution Solved by Shimejii,
ram is doubled when shown like that , if it shows its running 1600, its actually 3200 :) \
Also the command center reading is going to be wrong on temps, the ryzen master will be a bit more accurate
Hi,
I got MSI B450M Mortar MAX, Ryzen 3800x, and HyperX 64G ram hx432c16fb3k2/64
in MSI BIOS i am using profile 1, DRAM should be 3200Hz, and i can see the same in command center below.
However, in Ryzen Master, it shows the memory clock as only 1600hz, is it something wrong?
Also, I realize that the CPU temperature is different in two software, as you see below 35C vs 30.45C ..
any idea?
Thanks
https://linustechtips.com/topic/1157130-ryzen-master-issue/
https://linustechtips.com/topic/1157130-ryzen-master-issue/#findComment-13308262
