I have yet to run my h100i full load and I know that the idle temps dont mean much but they are averaging 30-34* c. Is that normal?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/115630-h100i-temps/
@Swegly
Hey. Yup, my idle temps are around that. You can use Corsair link to monitor the temps of the CPU and the water in the loop. It can be quite handy, just to make sure that the water temps are decent (under load mine is around 35 degrees C) and my CPU temps are 75-80.
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546131
And your at 4.5GHz DAAAAYYYUMMM
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546136
Yup!  :D (I do have to ramp the fans up a little) but other than that, it's a good cooler!
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546145
@Swegly
Elven
my h100i water temps are 31* idle. Thats good?
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546147
@Swegly
Elven
Yup ^
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546149
Load temperatures are the most important. If those aren't too high, then you're fine.
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546151
It's fine.
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546153
with a 3770k at 4,5 Ghz paired with a  100i 75-80 degrees isn't impressive at all, if anything hes at the thermal limit as to where you should push your cpu before if gets stupid.
75-80 stress testing is what I get with my 4670K @ 4.6 with an NHD14.
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546159
It usually depends on your ambient temperatures, whether or not you've overclocked your processor, and, if so, how much you've overclocked it. My 4670K idles anywhere between 22°C and 28°C, but that's with no overclock, a Cooler Master Glacer 240L with two Noctua NF-F12s, and the heating in my house sucks. In any case, 30°C-34°C is a perfectly acceptable range.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1546214
Putting in a few words just to reassure you, that's what I'm getting at idle with a 4670k. Full load @ 4.4GHz gets it up to mid-70s, though my fans are plugged into the motherboard headers and not the pump itself (somewhere between silent and normal setting for an h100i).
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1552860
  • 2 weeks later...
My H100i gets 28-29 C idle @ 4.5 GHz, 50 C when gaming, 100% load is ~70.
My GPU also idle's at about 35 C, gaming 50 C, 100% load 75-80 C.
Using SP120 and AF140's from Corsair.
CPU: i7-3930K @ 4.8GHz MOBO: IV Gene RAM: 16GB Crucial Ballistix Tactical Tracer 1866MHz GPU: GTX 780 Ti CASE: Corsair 350D STORAGE: 2 x Samsung 840 Pro 256 GB, 2x WD Red 4TB
PSU
: EVGA SuperNova 650W DISPLAY: 1 x ASUS VG248QE, 3 x Dell U2414H COOLING: Corsair H100i INPUT: Corsair Vengeance K70, SteelSeries Sensei AUDIO: Sennheiser HD 280 Pro, ATH-M50s, Beredynamic DT770 Pro, Steelseries H Wireless
https://linustechtips.com/topic/115630-h100i-temps/#findComment-1612074
