Would it potentially boost the performance of the cooler to have more than 2 fans hooked up to a 240 mm radiator? Have a ton of case fans and was thinking about adding these to my radiator opposed to just using the fans that come with it 2 intake(to the radiator) and 2 exhaust (from the case). Would this be beneficial or just stupid? Would it be worth the additional power draw from the extra fans at all?
https://linustechtips.com/topic/1155629-aio-cooling/
On 2/14/2020 at 9:38 PM, Techea said:
How can anyone know if even you think is a stupid idea? Do you think anybody tried that before? Go ahead and do the experiment. I'm also curious if it cools better. Please let me know.
I did my test. It seems to help a little bit. About 2-5C not quite worth it in my opinion. If they were static pressure, it might work better. I think the issue is that I’m using 2 case fans that aren’t mounted to the radiator in addition to the 2 mounted static fans.
https://linustechtips.com/topic/1155629-aio-cooling/#findComment-13302343
2-5c is a pretty significant drop. You're probably not going to see much more of a performance difference with better fans.
https://linustechtips.com/topic/1155629-aio-cooling/#findComment-13308006
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
https://linustechtips.com/topic/1155629-aio-cooling/#findComment-13308128
