After seeing the new XG270QG by Viewsonic on JayZ's Two Pennies I've decided to give a high refresh rate monitor a chance (normally just using tv's at 60hz and consoles at 30).  Unfortunate for me, I've grown accustomed and spoiled by a good audio system on a computer (thanks to using tv's instead of traditional monitors).  Having had a pseudo home theatre pc setup with game consoles and a pc all on the same tv/speaker system has started causing problems as I attempt to replace the now 9 year old tv.  I have a modern pc now that can game at over 60fps and want to give it a go, but no pc monitor supports an easy home theatre audio solution.  I've since hunted down some quality hdmi switchers, dacs, and a few sound bars to consider as options.  The downside to all of these is that speakers with acr-hdmi (like a pass-through) and splitter/switchers don't support more than 60hz signals as an output, but recently had a spark of madness that may or may not work.
I'm planing to buy a Yamaha YAS-108 sound bar and make use of it's arc channel (handles 4k at 60hz) to handle a single home console, while the pc's gpu will send audio to the speaker via hdmi (not passing it through) and a video signal to the XG270QG via display port.  My question is, will running hdmi and display port out of a gtx1080 cause performance problems in running games or even work in the way I think it will?  Has anyone ever tried something like this?
https://linustechtips.com/topic/1155201-crazy-monitorspeaker-solution/
Why not wait and buy the LG CX 48" OLED. It will trounce Monitor quality and can do 120hz. 4k, VRR, and BFI.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
Because this is going on an office desk and not in a living room (that's why i called it a pseudo home theatre pc).  It's my home office work space that i also use for gaming and movie watching.  I also can't wait since my cat peed on the desk monitor and killed it (literally just after i posted this).  Having to type from a living room tv really sucks.  it's super cheep and totally not color accurate.
Fair enough.
I suggest u look at the following. Has all the important info you need in the reviews.
https://www.rtings.com/user/ratings/mQInJLi7qiX8GQ
6 hours ago, SolarNova said:
Fair enough.
Oh cool.  That's an awesome link.  I'll take a look at it in the morning.  Thanks very much.
