“Your computer” is also pretty vague.  This could be an apple IIe for all we know.
5 minutes ago, niels19992 said:
Wel, it's a computer with windows 10 installed on it if that helps
perhaps a bit.  This whole “I will tell you only the absolute minimum possible and make you derive additional information from it” thing is difficult.
Without knowing any information this is really hard.  Logitech makes a bunch of mice with several different pieces of support software which apparently you only may or may not have installed.  Win10 has generic mouse drivers but there are also drivers for specific mice and sometime software package that either talk to the generic driver or install their own.
I think I know where to find the drivers.. thank you.
