Hello,
i am going to buy the corsair vengenace rgb pro 3600mhz ram and a r5 3600 with a asus b450m mobo, my i5 2500k is really bad and i cant even alt tab out of applications.
i currently have rx 580 8gb (XFX Version) would it be worth the 3600 or do i get 2600? im thinking of getting a 3060/70 when they are realised and will i be able to use my mobo on ryzen 4000?
thanks in advance!
https://linustechtips.com/topic/1155061-upgrading-pc-need-help/
There isnt a reason why you wouldnt be able to.
asus b450m mobo
Would suggest getting sormthing else.
MSI max board with a VRM heatsink.
https://linustechtips.com/topic/1155061-upgrading-pc-need-help/#findComment-13292693
