does it matter which Cha_Fan Input I plug into?
Go to solution Solved by Slottr,
Doesn't matter
My new motherboard has 2 Chassis Fan inputs, Cha_Fan1 and Cha_Fan2, Does it matter which one I plug my Chassis Fan controller/computer case fan Controller into? Cha_Fan1 is in the middle of the Motherboard, Cha_Fan2 is on the edge and would make it easier for me to have good cable management.
Edit: Do I have to use the first one if I only have 1? or can I use any.
Edited by DaenerysTargaryen
