11 minutes ago, _kR15n said:
Hello, i recently bought a used Logitech G413 Carbon and it was working fine, but now when i press the backspace button it deletes everything until i press a different key. Why is that so and what can i do about it?
Try reinstaling the software, re-plugging it, it that doesn't work, RMA. Oh, and try pulling of the cap of the backspace button and putting it back on. Just in case,might help.
Edited by noxdeouroboros
https://linustechtips.com/topic/1154541-keyboard-help/#findComment-13288509
1 minute ago, _kR15n said:
I have just used keyboardtester.com to see if it was activating multiple times and it has recorded in the program as a single click, also i have checked logitech gaming software and it also reports single clicks.
RMA then. Try pulling the cap of the key and putting it back on first.
https://linustechtips.com/topic/1154541-keyboard-help/#findComment-13288563
 I have and i think i understand the problem, i do not have to use almost any force to activate it… A feather could probably activate it at this point.
https://linustechtips.com/topic/1154541-keyboard-help/#findComment-13288573
Then RMA, no other way about it. Well, you could change that switch yourself, but it's a recent purchase as you said so it doesn't make sense.
https://linustechtips.com/topic/1154541-keyboard-help/#findComment-13288583
it is a recent, already used purchase though...
https://linustechtips.com/topic/1154541-keyboard-help/#findComment-13288587
15 hours ago, noxdeouroboros said:
How did you manage that?
The plastic tabs that hold the switch in place were bent outwards so i just stuffed them back where they should be… Not a great fix but hey, at least it works as intended now!
https://linustechtips.com/topic/1154541-keyboard-help/#findComment-13291688
