Connect monitor to motherboard
Stoicplanet
Hi i wanted to ask if it's possible to connect my monitor to the motherboard and use my dedicated gpu because my gpu doesn't support vga and my monitor supports vga only and adapters makes the image quality bad
The connectors on the motherboard work only if your processor has integrated graphics.
It's unlikely you'd be able to use the dedicated video card for rendering the game, but redirect the output through the integrated graphics.
The quality should not be significantly degraded by converting HDMI or DisplayPort to VGA - simply make sure your actual resolution is as close to your monitor's native resolution.
