I need help with my first computer build.
So here are the specs and I want to know if this will all work together.
Motherboard:  Gigabyte GA-990XA-UD3
Procesor: AMD FX-8320
Graphic Card: VTX HD7870 BLACK
RAM: Patriot Viper3, 1600Mhz 8GB (1X8)
Power Supply: Corsair Gaming Series 2013 Edition 600 Watt, 80+ Bronze
CPU Cooler: Thermaltake Contac 39
Case: Thermaltake Chaser A31
HDD: WD Caviar Green 1TB SATA3
https://linustechtips.com/topic/11544-my-first-computer-build/
Firstly the power supply is bad. Get the cx600 its better and more reliable and its cheaper(many problems with the gs600 ive seen). The fx8350 is a lot better then the 8320 and i dont think its that much more expensive as well.
Listen if you care.
https://linustechtips.com/topic/11544-my-first-computer-build/#findComment-123151
change the CPU to a FX8350. its not that much more expensive
get a better PSU. if you are tight on the budget get a 500-550W because you wont need more than that unles you are going to Crossfire later on.
and please get a Barracuda drive from seagate, dont get a green drive if you dont have a separate boot SSD, even if you did dont get a green drive because  its way too slow and not responsive enough.
get a faster 7200RPM drive from Seagate they are very reliable.
and unless you are paying anything less than $30 for that CPU cooler. change it to a Coolermaster Hyper212 evo its arounf $35 and cutrrently im using that on my 2500k running at 4.6Ghz until i get a replacement for my H100( i broke it not a manufacture  fault or bad unit)
otherthan that it looks solid to me.
one other thing. dont drop a ton on RAM just get G.Skill Ram with 1600mhz and you will be fine. and they look good too.
https://linustechtips.com/topic/11544-my-first-computer-build/#findComment-123268
I agree with you (amintha1992) on the upgraded CPU and especially the WD Green to a Seagate. The Green drive would not give you the performance you'll need. That will be a huge bottleneck. I would suggest an SSD for your system boot drive instead of a mechanical drive. Use your mechanical drive as storage and/or extra apps/games. Plus, Seagate, in my experience, outlast and out-perform any and all WD drives. IE... When I first started out playing with hardware, I went with nothing but WD and was extremely disappointed when I had three WD Drives fail on me within a year. Since then all I buy and use are either Seagate drives or Hitachi drives.
Good luck with your build!
https://linustechtips.com/topic/11544-my-first-computer-build/#findComment-124265
Make sure you get a memory module kit (pairs or 4x) as single one module is not ideal for DDR3. you should look into the spec of the m/board and see what recommended memory kits they suggest.
Sata 3 is good yes, on all drives.
maybe you should look into a blue ray / dvd drive
if you want to save on cost the FX6300 is a good buy and save on power consumption (95w vs 125w) the 8 core will only benifit if your doing lots of high end video editing / professional designing work etc, a good 6 core would be better for games if your on a budget.
got to love Asus components
https://linustechtips.com/topic/11544-my-first-computer-build/#findComment-124497
what about something like this
http://uk.pcpartpicker.com/user/mvitkun/saved/1wWm
is it within your budget?what is your budget?
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/11544-my-first-computer-build/#findComment-124527
