I receive a lot of blue lines down my screen with my GPU The computer was dropped on move, I already preparing for the worst case scenario that it is done/fried! the lines I get are really similar to this.
GPU is Sapphire Vapor X Radeon R9 280x 3Gb
anything helps, computer is 5 years old the specs are
NZXT Phantom Case Motherboard-Gigabyte Z97 Gaming 5 Motherboard Ram- G_SKill Sniper Gaming Series 32GB 4 sticks DDR3 1600 (PC3 12800) CPU- Intel Core i7-4790k 4.0 GHz LGA 1150 Socket CPU Cooler Master V8 GTS - Horizontal Vapor Chamber and 8 heat pipes GPU - Sapphire Vapor X Radeon R9 280x 3GB DDR5 SSD- Kingston v300 Series 2.5" 240GB Sata III HDD- 2 Western Digital Bluue 1TB Each 7200 RPM cache 6.0 Gb/s... 3.5" OS-Windows 10 Pro 64Bit Key Board- Tt esports Challenger Prime Backlit gaming Keyboard Mouse-5500 DPI 7 button Led optical Usb wired gaming Mouse Mice for Pro Gamer
I replaced my GPU with an older one (AMD Radeon HD 7700 sereis)  but doesn't really hold to my expectations
https://linustechtips.com/topic/1153906-gpu-problems/
You tried a different GPU and it’s still doing that?
If so, it could be the PCIe slot or the monitor. Try a different PCIe slot as a place to start. But if you said you used a older GPU and it fixed it, just try and reinstall the GPU, it could have just jumped out a little bit.
https://linustechtips.com/topic/1153906-gpu-problems/#findComment-13283657
