Hi I'm a tech newbie, I really like the m17 alienware, my question is as a casual gamer will the base model 1660ti  with the i7 be enough for the occasional game? Will I lose a lot of battery life with the 2060 is it worth it?
Edited by Jimmy f
https://linustechtips.com/topic/1153874-tech-newbiw/
on their website, the only config with the 1660 ti has 8GB of ram, whereas the 2060 config has 16GB, which might also be important to consider.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1153874-tech-newbiw/#findComment-13283391
just to clarify, are you looking for a new laptop? if so, do you have a spesific budget? location?
the 2060 will draw more power as it is the more powerful GPU
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1153874-tech-newbiw/#findComment-13283399
Yeah I'm looking for a new laptop and I really love the way the m17 looks. On the website I messed around with the configurations. The I7 with the 1660ti and 16gb is the one I'm looking at. I'm just wondering if that GPU is good enough for casual games or should I spring for the 2060 I also want to know how much battery life would differ.
https://linustechtips.com/topic/1153874-tech-newbiw/#findComment-13283640
You can configure it with 16gb and an I7. My concern is just the GPU is the 1660Ti good enough for casual games or should I get the 2060 also is the difference in battery life significant?
https://linustechtips.com/topic/1153874-tech-newbiw/#findComment-13283644
