Well met,
I have a Crosshair VI Hero Wi-Fi Motherboard and it is lacking the 3 Pin 5V ARGB Header. Are there controllers that are connected via a USB2/3 Header on the board that allows you to control the RGB via software like Asus Aura Sync?
I know the ROG Terminal exists but it is fairly pricey for what it offers. Are there any other options for such a product?
https://linustechtips.com/topic/1153811-argb-controller/
1 hour ago, Assarad said:
Well met,
thermaltake, corsair, nzxt, coolermater, asus, lamptron, aquacomputer, and ek might get in to it. coolermaster is crap thow so don't recommend it.
https://linustechtips.com/topic/1153811-argb-controller/#findComment-13283042
8 hours ago, Assarad said:
Can you name any specific product?
depends on what your looking for. are you looking for argb or rgb. what software do you want to use. all you have to do is put the name in ammazon and add rgb to it like thermatake rgb.
asus rgb
coolermaster rgb
aquacomputer rgb
lamptron rgb
nzxt rgb
thermaltake and corsair both have rgb fans and argb fans and many sizes. corsair rgb fans are not software controlled thow only there argb stuff is.
https://linustechtips.com/topic/1153811-argb-controller/#findComment-13284354
  • 3 weeks later...
