noob help VB program (IF loop)
Solved by fizzlesticks,
The problem if that you are defining "Dim iMinWaarde As Integer" inside the function. You need this to be a global variable and only set to 999 once so it does not get redefined to 999 every time the timer goes off.
Edit: Or you can not define it at all and just read the value back from lblValMinimumTemperatuur.Text
