Do someone know which can be the couse of this strange artifact I get on my monitor from time to time?
I think I started seing this after I tried to oc my monitor refresh rate, but in the same period I also changed GPU so I don't know if that could be the cause. I tried switching HDMI cable but unfortunately I don't have a DP cable to try.
Could it be some Gpu problem, or is it more probably a monitor issue?
It also usually disappear if I restart the pc
https://linustechtips.com/topic/1153526-strange-artifact-please-help/
1 minute ago, _Syn_ said:
Does it move with the Start Menu animation?
Regardless though I think this is more GPU related, it's extremely rare for a monitor to have this many faulty pixels, is your monitor still overclocked? and what's your whole system specs?
Quote or Tag people so they know that you've replied.
yes it moves
I wasn't thinking about dead pixels in fact. The monitor is at stock refresh now. My sistem has a gtx 1070 asus dual oc, and an i7 6700.
since the previous gpu was an AMD rx 480, could it be that I have some driver or component left after uninstalling AMD driver that is cousing problems with Nvidia ones?
1 minute ago, Piliffo said:
yes it moves
Then it's definitely a GPU issue, might be faulty VRAM or you have it overclocked to the point that it's not stable.
You could try using DDU to completely uninstall your drivers and reinstall them again.
try resetting ur display driver.
Win+Ctrl+Shift+B
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
ty
4 hours ago, Piliffo said:
when I press this combination should I see something happen or it just does it in the background?
Screen should flick black then restore.
