may i know... what PSU are you using? model and wattage
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1153513-problem/#findComment-13280837
4 minutes ago, Lelouch Lamperouge said:
Hello,
Recently I bought RX 580 Nitro+ 4gb
For some reason when I run any game system stopped working. Keyboard turned off, mouse ain't responding. When I restart the pc everything works fine.
I updated the drivers tho.
Should I do clean reinstall of Windows?
So, is everything working fine now? If it happens again, I'd suspect the PSU.
https://linustechtips.com/topic/1153513-problem/#findComment-13280840
1 minute ago, Lelouch Lamperouge said:
Well 500w nJoy
It helps to know the specific model, as there are a couple of those available.
Also make sure you quote us or use @berberries so we can see your responses.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1153513-problem/#findComment-13280843
@Fasauceome
https://www.njoy.ro/PSU/synergy-500-bulk#specificatii
I have first version of it v1, it came with only one PCIe - 8 pin connector.
https://linustechtips.com/topic/1153513-problem/#findComment-13280885
2 minutes ago, Lelouch Lamperouge said:
@Fasauceome
It's hard to say one way or the other if this PSU is bad or not, but the price tag of 36 euros doesn't inspire confidence
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13280893
Should I get the new psu?
My config
Ryzen 3 3200ge
8gb ram ddr4 Hyper x
gigabyte ga a320msh 2 b350 chip set
Sapphire rx 580 4gb nitro
https://linustechtips.com/topic/1153513-problem/#findComment-13280899
My config
Ryzen 3 3200ge
I wouldn't advise getting a new PSU unless you can be certain that the PSU is the cause of the issue. Would it be possible to borrow a friend's PSU?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13280903
I do hear some noice coming from PSU tho.
What software should I use to stress the gpu?
https://linustechtips.com/topic/1153513-problem/#findComment-13280908
The noise could just be cool whine, doesn't really mean it's broken.
For software, I like to use Aida64, and Furmark is also quite popular.
Aida64 download
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13280915
I just reinstalled windows, going to install fresh drivers and start benchmarking.
https://linustechtips.com/topic/1153513-problem/#findComment-13280917
24 minutes ago, Lelouch Lamperouge said:
not sure what you mean to show me here, this is just the trixx dashboard.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13280963
Once it hits 200w its good night for my system. imageproxy.php?img=&key=0c2a8b7d8afbc61a
sounds an awful lot like a PSU problem, but still could also be a GPU problem. Again, if you could pop this RX 580 into a friend's PC to make sure, that would be ideal. The Nitro+ should also have a dual BIOS switch, have you tested with both BIOSes?
as for a potential PSU replacement, what country are you buying from?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13281063
I switched to default bios. I don't have any friends that I can test it with.
Would 600w-750w do the job?
https://linustechtips.com/topic/1153513-problem/#findComment-13281094
450 watts does the job, you just need a better unit. where are you buying from?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13281095
I'm buying from Serbia
Unfortunately I don't know anything about Serbia pricing, so check out some of these units:
Corsair CX450, CX550
Be quiet puer power 10, pure power 11, system power 9
Cooler Master MWE gold
Xilence performance X
XFX Pro XXX
I find that these units appear to be fairly common at good prices overall. And of course, feel free to check out the PSU tier list.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13281101
7 minutes ago, Lelouch Lamperouge said:
This PSU falls into our B tier which is what I'd recommend
https://www.emmi.rs/napajanja-i-dodatni-ventilatori-napajanje-600w-cooler-master-mwe-white-series.11.html?productId=87133
I don't know anything about "falcon gaming" PSUs but power supplies with gaming in the name usually are not promising in my opinion.
Unfortunately, I don't remember if the smart RGB is better than the regular smart
https://www.emmi.rs/napajanja-i-dodatni-ventilatori-napajanje-500w-thermaltake-smart-rgb-80plus.11.html?productId=84402
but @LukeSavenije can confirm for me
Primary PC:
PSU tier list
https://linustechtips.com/topic/1153513-problem/#findComment-13281486
