Hard and soft tubing in same build
Solved by Neggy-Z,
8 hours ago, TheRealEaro said:I was thinking of using tap water and then using some destilled water for one final flush
This is pretty much what i do for blocks, for rads i like to use hot water + white vinegar, cap off the ports and give them a good shake for a few minutes, you may need to repeat this a few times depending on how dirty your rads are.
The blitz cleaning kits aren't necessary for new parts.
I can't remember how long i had the fluid in the loop, it was probably closer to a year before flushing.
