I am searching for old laptop model similar to Asus N50V, but model I am searching for had flippable webcam mechanism. It was laptop from about 2009 :D
My grandmother still using it and I need to know if she have 64bit instductions before I arrive to her with Win10 installation :D She still using Win 7 on there and I need to upgrade it :D
Fullstack developer & Electrician & PC HW lover!
https://linustechtips.com/topic/1153435-searching-for-laptop-model/
Isnt the model written on the bottom?
Cmon old people, old hardware, OP better try and explain how to view system information in software... or set up team viewer for remote access... I am almost certain CPU in that thing is 64 bit capable, but 32-bit OS still might be installed instead...
Worst case scenario you will have to clean install win 10 that you bring with you...might as well bring both versions...
Yea. I took both... But it was 64bit Core 2 Duo T9400 ;)
BTW it was M50V model :)
