I have a KDM Power 775w power supply in my system, 3 fans, 2 HDD's, an i3 3220, And a GTX 780 Ti.
When my cpu and gpu both are under load the pc shuts down as if i just unplugged it. The gpu is at stock clocks, the cpu is a little overclocked 3.6Ghz (3.30 is stock)
Is this taking too much power or what? I've had a few power supplies in the past, a 350w without the GTX 780 ti and it was perfectly fine, until i had gotten the gpu and it had burnt out the psu when it was under heavy load, it'd get hot and smell like burnt plastic.
This current power supply gets a little warm but not alarmingly warm.. Any ideas?
Thanks.
https://linustechtips.com/topic/1153338-775w-not-enough/
Ew ew ew ew ew ew. That power supply. Yeah I doubt it is even rated for 775w. That is likely your problem. I would replacement it and that will likely fix it. I have never even heard of that brand.
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/1153338-775w-not-enough/#findComment-13279643
What a crappy PSU, throw it out, you could easily power that system on a 450 - 500w PSU. Get something 80+ Gold from a reputable brand.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1153338-775w-not-enough/#findComment-13279648
Almost 800W could run your System 3 times. Maybe the fact its a cheap Garbage PSU has something to do with it.
Dont safe Money on the PSU next time. Buy Quality.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1153338-775w-not-enough/#findComment-13279649
It's not that 775W isn't enough power.
It's that the PSU you're using is absolute garbage and probably only capable of putting out about <50% less of its advertised power.
From what I can gather, a KDM 775W is only about a 500W power supply (on a cold day).
https://linustechtips.com/topic/1153338-775w-not-enough/#findComment-13279664
About 30 minutes after i posted this, My 780Ti Died on me... Horrible timing.. LOL.. Definitely getting rid of this power supply..
It's by KDM power, But labelled as a "Mi PC" which is kind of confusing but oh well.. shouldn't have paid $40 USD for this thing
https://linustechtips.com/topic/1153338-775w-not-enough/#findComment-13280490
