I have fried in the past like you, just by installing it inside.
And it was from the cable that come from the case, POWER LED/HDD/AUDIO/POWER ON AND USB.
One of my USB was short circuited, and just like than thew mobo died.
Check you cables, try to post w/o them.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1153043-help/#findComment-13277349
Why could I put a old asrock z97 anniversary edition board in there and boot just fine?
58 minutes ago, The_russian said:
Are you putting the motherboard standoffs in before you install the motherboard? Are you connecting the PSU correctly? Also how did you come to the conclusion that they are fried?
I had the motherboard working before installing it in the case, I had it running windows 10 pro just fine
The standoffs are preinstalled, and are correct for the mobo
It attempts to start everytime I jump the jbat so I dont know what's happening anymore or how to fix my mobo
https://linustechtips.com/topic/1153043-help/#findComment-13277359
build your system outside of the case see if it works.
https://linustechtips.com/topic/1153043-help/#findComment-13277371
Just now, FirestarThunder said:
I did that originally, and it worked fine, but after I put the mobo in the case, it wont post at all, I'm trying a cmos reset to see if it will work again
I told you maybe the case cables are short circuit
https://linustechtips.com/topic/1153043-help/#findComment-13277377
place something (paper sheet / foam) below the motherboard to isolate any electrical contact to the case.
do a barebone install, cpu, mem and gpu only, don't plug anything yet, see if it boot.
https://linustechtips.com/topic/1153043-help/#findComment-13277380
1 minute ago, FirestarThunder said:
Do you think a cmos reset will bring the mobo back to working condition again?
How so, if it's dead?
EDIT: what PSU are you using?
https://linustechtips.com/topic/1153043-help/#findComment-13277384
So it worked before you put it in the case, have you tried taking everything back out and trying to boot it? A lot of newer motherboards have good protection from short circuits and will still work once you fix the short circuit. I would try taking the motherboard out and testing everything outside of the case.
Edit: please post a list of all of your specs when you need help troubleshooting something.
https://linustechtips.com/topic/1153043-help/#findComment-13277387
It wont boot at all, even after a cmos reset, I just tried
https://linustechtips.com/topic/1153043-help/#findComment-13277389
After taking everything out of the case?
So you mean now if you take it out of the case it will work?
https://linustechtips.com/topic/1153043-help/#findComment-13277396
No, it wont work at all
https://linustechtips.com/topic/1153043-help/#findComment-13277400
Is there anyone that could figure this out?
My system(at least what I want to have working)
AMD ryzen 5 3600
Noctua NH-D9L cpu cooler
Msi x570 a pro
16gb GSkill Z Neo
AMD R9 390
Antech 1000 semi-modualr
1 LG 1080p ips led
1 Dell LCD
Reddragon mechanical gaming keyboard
Logitech G602 gaming wireless mouse
Edited by FirestarThunder
More photos
https://linustechtips.com/topic/1153043-help/#findComment-13277428
