RX 570 Liquid Cooling???
Go to solution Solved by MaratM,
If you want a really compact build there is a waterblock for sapphire pulse rx570 4gb itx, it is made by bykski but it costs more than than the card637677D9-213D-4DC9-AE3F-AC23DAEBCD07.jpeg.b7d799372d601d60038818a3e52d70ec.jpeg
you can find it on ebay or aliexpress
So i'm making a small compact computer and i want to minimise as much space without compromising on the cooling this is going to be a budget computer that is portable. So is there currently a water block that will water cool the RX 570?
If not what GPU has or supports a water block that fits? And any case recommended for a mini itx motherboard size and power-supply that has enough to supply the graphics card and the CPU as well as driving all the necessary components with enough power and water cooling the CPU without problems. Even if it has to air cool some parts like the CPU or something.
https://linustechtips.com/topic/1152931-rx-570-liquid-cooling/
Water-cooling a low-end card like the 570 is useless, cost/performance is horrible, so nobody makes a block for it.
Zotac/Gigabyte make some good "Mini" cards, you could look at a 2060 from them.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1152931-rx-570-liquid-cooling/#findComment-13276430
If you're doing a full copper custom loop, I believe EK has a GPU-only block that fits the 570.
That loop is gonna cost you a few hundred dollars easily tho- if you're just doing it for the fun/bragging rights, then go for it, but realistically you'd do better performance wise with air cooling and a new GPU.
Edit- are you looking for a full loop or an AIO? The Kraken G12 should fit the 570 if you want to go AIO, but it might be a bit tall to fit in an ITX case.
https://linustechtips.com/topic/1152931-rx-570-liquid-cooling/#findComment-13279221
CPU: i7 8700K OC 5.0 gHz, Motherboard: Asus Maximus VIII Hero (Z170), RAM: 32gb Corsair Vengeance RGB 3200 mHz, GPU: Asus Strix OC gtx 1080ti, Storage: Samsung 950pro 500gb, samsung 860evo 500gb, 2x2Tb + 6Tb HDD,Case: Lian Li PC O11 dynamic, Cooling: Very custom loop.
CPU: i7 8700K, Motherboard Asus z390i, RAM:32gb g.skill RGB 3200, GPU: EVGA Gtx 1080ti SC Black, Storage: samsung 960evo 500gb, samsung 860evo 1tb (M.2) Case: lian li q37. Cooling: on the way to get watercooled (EKWB, HWlabs, Noctua, Barrow)
CPU: i7 9400F, Motherboard: Z170i pro gaming, RAM: 16gb Corsair Vengeance RGB 3200 mHz, GPU: Sapphire Vega56 pulse with Bykski waterblock, Storage: wd blue 500gb (windows) Samsung 860evo 500Gb (MacOS), PSU Corsair sf600 Case: Motif Monument aluminium replica, Cooling: Custom water cooling loop
https://linustechtips.com/topic/1152931-rx-570-liquid-cooling/#findComment-13280040
  • 2 weeks later...
i just wanted an aio cooler as i thought about a full loop but that would make it very hard to cool both a CPU and GPU in a very short space that might not work very effectively or at all so i looked for a case that is slightly bigger and i can see it somewhat fitting maybe have to do a bit of DIY on it and i just wanted to do it for fun and experimentation, but if it is too much i will just get a new gpu and just leave it to be air cooled. And it seems i can mark one as solved but technically both the two comments has solved it so yeah. sorry for late reply busy with college work.
https://linustechtips.com/topic/1152931-rx-570-liquid-cooling/#findComment-13303651
i just wanted to see if the Rx 570 can be water cooled as i saw a few blocks but very little information was said about on google and youtube as i thought they were fake and finding forums on this kind of stuff doesn't seem to exist. one of the posts the person says there is a block but it will cost more than my gpu i just want to do it for experimentation and fun as maybe a bit of diy and see what i can get for a budget but if it costs too much i will just go for all air cooled and upgrade gpu.
https://linustechtips.com/topic/1152931-rx-570-liquid-cooling/#findComment-13303703
