Mid game my audio cut out from my headphones.
I am running a focusrite 2i2 gen 2.
I restarted the PC. I unplugged and plugged the usb. Nothing
I tested the headphones through different ports. The headphones work.
The mic still works with the focusrite and I can hear my headphones through it's port with the direct monitoring. So the Aux jack works on it.
When I have a video playing and the device set to the focusrite, the volume mixer doesn't show the browser or anything else having sound levels. As if nothing is playing.
I'm stumped.
Has to be a setting or driver. Not sure
please help
https://linustechtips.com/topic/1152918-no-audio/
1 hour ago, StarsMars said:
Fixed. Even though I set it as the default device. After running troubleshooter, it said it was not the default device.
Thanks windows
Fairly sure SupremeFX and Wndows were conflicting trying to control the devices.
Sometimes Discord dicks around with audio settings for no good reason. Glad ya fixed it easily.
https://linustechtips.com/topic/1152918-no-audio/#findComment-13276609
