8 minutes ago, iamlegs said:
so i have 2 more 3 pin fans and ther are no more on the mother board or the psu any other way?
Buy a molex to multi-fan header or SATA to multi-fan header depending on what you have available off the PSU to power it.
Can by either a splitter or HUB but the hub needs 1 header on the mobo (Im not sure I haven't tried my hubs without this...it may just power up fully from the SATA power only) examples:
https://www.newegg.com/p/N82E16812423165?Description=molex fan splitter&cm_re=molex_fan_splitter-_-12-423-165-_-Product&quicklink=true
https://www.newegg.com/black-en-lab-2ft-60cm-pwm-4pin-fan-hub-splitter/p/1W7-005X-00042?Description=fan hub&cm_re=fan_hub-_-1W7-005X-00042-_-Product
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276114
is ther a way to not buy anything?
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276127
Im sure there is a way to wire up a molex header from the PSU with some bare metal, cover it in electrical tape and hope for the best as all you need is power and ground (from what I understand which isn't much) However I am only so jank and haven't done anything like that myself.
Shop around, a fan splitter can be found on sale for $1 shipped, and I have purchased many hubs for $7 shipped or less.
You could also purchase a motherboard fan header splitter so as not to only limit yourself to PSU capable options.
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276132
Splice the red and black wire from fan1, cut and soldier those to the red and black wires from fan2, don't connect the yellow or white wire from both fans (it's the RPM sense wire).
Plug your 1 connector (with 2 fans on it) to the motherboard.
Or, you can buy a molex to 3 pins adapter, or a splitter, like @Tristerin mentioned.
EDIT :
thanks Google image :D
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276164
EDIT :
Beautiful and doesn't even sound jank.  I could easily do this.
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276166
EDIT :
i dont rly understand
my 3 pin fan has no cable colour
and ther no 3pin connector on it so i dont know what to do
my motherbaord only has 2 fans connecors
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276428
Can't help with that, but what I posted above will work if you connect the correct wires.
???? so your fans are not 3 pin fans ????
That's why I proposed either : soldering the fan wires together (free option), or buying adapters like @Tristerin said.
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276443
i mean that ther are no 3pin connectors on my mother board
https://linustechtips.com/topic/1152889-3-pin-fans/#findComment-13276469
