Hello,
The PC specs are:
FX 6300, M5A78L-M/USB3, 2x4GB RAM, GTX 750Ti, 2 HDD's
I am planning to overclock this CPU a little bit. And probably but not sure I would upgrade the GPU to a 1050Ti or 1650 in the future.
Would CX450 be enough to run this system under full load?
https://linustechtips.com/topic/1152711-advice-regarding-cx-450/
10 minutes ago, seon123 said:
Yes. Both the 1050 Ti and 1650 are 75W cards, so expect the system to draw 150-200W under load.
Would I be able to overclock the CPU(somewhere around 1.35V and 4-4.1GHz) and still have some headroom with the PSU without causing power failures or something like that?
Absolutely not! That motherboard is not designed for overclocking. It has no heatsink on the power delivery components. You can end up frying the VR mosfets thus killing your board.
Ryzen 5 2600 3.9Ghz all cores 1.175V | MSI X470 Gaming Pro | 16GB ADATA Gammix D10 @ 3000C16 | Sapphire RX 5700 XT Pulse | Samsung 970 EVO Plus 250GB & 2x Samsung 860 EVO 500GB | Super Flower Leadex II 650W | Phanteks P350X
Asus VG245HE 24" 1080p 75hz | Logitech X-540 5.1 | Logitech G710+ MX Brown | Logitech G502 Hero | Logitech G440
I have a 80mm fan blowing towards the VRM's. It's just a baseline I just said in the last post about the OC, I would bring it down according to the temps though.
Take your chances, I guess.
