No Post Troubleshooting
Solved by Chiyawa,
Well, through your troubleshooting steps, I would say I highly suspect your motherboard is faulty. There might still be one step you haven't try:
Shut down the power, and remove the CMOS battery, try pushing the power switch of your PC for 30 seconds, then plug everything back and see if it post.
If the system doesn't post, there could be 2 reasons:
- Chipset, or the motherboard controller faulty,
- BIOS EEPROM faulty.
I thought LGA1150 is for Intel 4th gen Core series CPU. Even if you have 3rd gen processor, it won't fit in the motherboard.
