What will happen if my laptop SD card slot pins are bent and broken and touching the surface? Is it safe to use my laptop or it can do short circuit tell me
The picture link is given below which will describe the situation of my SD card slot kindly tell me about this.
Link:
Thanks and Regards
https://linustechtips.com/topic/1152601-laptop-sd-card-slot-problem/
