I'm building this computer focused on gaming and occasionally for school work (photoshop and animated).
CPU: Intel Core i9-9900KS 4 GHz 8-Core Processor 2
CPU Cooler: Gigabyte GP-ATC800 51.7 CFM CPU Cooler 1
Motherboard: Gigabyte Z390 AORUS MASTER ATX LGA1151 Motherboard
Memory: Gigabyte AORUS RGB 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive
Storage: Silicon Power A80 2 TB M.2-2280 NVME Solid State Drive
Video Card: Gigabyte GeForce RTX 2080 Ti 11 GB AORUS XTREME WATERFORCE Video Card
Case: Cougar Gemini T ATX Mid Tower Case
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Home Full - USB 32/64-bit
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120 mm Fan
Monitor: Gigabyte AORUS KD25F 24.5" 1920x1080 240 Hz Monitor
Keyboard: Gigabyte Aorus K9 Wired Standard Keyboard
Mouse: G.Skill RIPJAWS MX780 Wired Laser Mouse
I want this air cooler but i could use alternative cpu cooling like air cooling or liquid cooling (prefered rgb)
2 which is better 9900k vs 9900ks
https://linustechtips.com/topic/1152274-revised-building-plan/
that's quite a bad cooler, not suitable to cool a 9900k. I'd recommend a noctua dh-15 instead.
secondary storage can be sata instead of nvme. curcial mx500 is a good option and should be much cheaper.
if you don't play on both at the same time, there's no point in having both at 240hz.
https://linustechtips.com/topic/1152274-revised-building-plan/#findComment-13272112
