Questions Regarding Ryzen
Go to solution Solved by Metallus97,
Talking about Ryzen 3xxx :
1. The interconnect between the IO die and the cores and even the cores themselves is called infinity fabric. That runs synced with the mem speed up to  3200Mhz. After that it gets decoupled. So its recommended to run 3200-3600Mhz mem with good timings. Here is a verry conclusive and in depth look at it:
Less time?:
2. As you see in this videos up to a certain point: yes
3. Depends on the apps. For gaming 16GB is still fine and 32GB more than you need but nice if you can afford it. But prioritize other stuff over that!
4. yes
Hi there!
i am planning to upgrade to ryzen somewhere in the future seeing it as a better value for money platform.
i have a few questions regarding about Ryzen since i have no experience working with it.
1. What is it with ryzen and fast memory?
2. Does memory have a huge impact in performance?
3. Does more memory translates to more performance?
4. Does all Ryzen CPU share the same AM4 socket?
any conclusive answers are appreciated
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1151520-questions-regarding-ryzen/
Less time?:
4. yes
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
Less time?:
4. yes
i currently have the corsair vengance lpx 2666, should i keep it or should i just get a new set of ram? (looking to upgrade to 16)
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Idd upgrade that. You can try your luck OCing but from what I have read the LP stuff ain’t the best modules so I think you wont get much more perf out of them. So you currently have 8GB? Then It’s anyway worth it to get new ram.
Oh and most important: You already wrote set of ram. So thats good, because Ryzen on single channel is really a hard bottleneck
1 minute ago, Metallus97 said:
Idd upgrade that. You can try your luck OCing but from what I have read the LP stuf ain’t the best modules so I think you wont get much more perf out of them. So you currently have 8GB? Then It’s anyway worth it to get new ram
just to clarify its 2x4 not 1x8
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
Just now, Nicnac said:
While they still do benefit from fast memory, I think that this-gen ryzen does not depend on it as much as earlier generations
Correct, but watch the videos. It’s still a major factor and its important go at lest go above 3000Mhz
Just now, Metallus97 said:
Thats nice but yeha in that case just get a 3200 Cl16 2x8GB kit or something along those lines
Thanks a lot for your help!
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
