Need help with CPU upgrade.
Go to solution Solved by Crunchy Dragon,
2 hours ago, captskully said:
Probably shouldve asked this to begin with lol, but for what my system is right now, would the upgrade be much of a difference? Or should I hold off?
It's really up to you, I would personally run the 2600 for another year or two depending on what it's being used for, but I also have a tendency to run my hardware more or less into the ground before upgrading.
Hello friendos. So I've been looking to upgrade my Ryzen 5 2600 since its been a year and was wondering whatd be some good choices? My friend suggested a Ryzen 5 3600x due to it being on sale for the same price of a 3600 right now (269$CAD). But I'm open to all suggestions. here's my pc at the current time.
GPU: Radeon 5700XT 8GB Evoke
CPU: Ryzen 5 2600 (With Scythe Mugen 5 Rev.B)
RAM: 16GB Corsair Vengeance LPX 2666mhz
PSU: Corsair CX550M
MOBO: MSI B450m PRO-VDH
https://linustechtips.com/topic/1151081-need-help-with-cpu-upgrade/
3600x is a good choice, especially if it's for the same price as a 3600.
Edit: make sure your BIOS is updated to support the 3600.
ensure you upgrade bios prior to swapping CPU to 3600x as suggested.
B450 would most likely need a bios update to support 3rd generation Ryzen
I would also while not mentioned consider M.2 gen drive for storage if you dont have one already.
It is significantly faster than a traditional SSD.
I have the latest update from the MSI website, at least i believe so. The latest one was released December 6th.
I have an M.2. Load times for gaming dont seem more than 1sec fast than my SSD but moving files sure as heck does.
You're all set then.
