So I just completed my first build. The specs are the following:
Asus Tuf X570 plus wifi
Ryzen 7 3700x
Asus Radeon RX 5700 XT 8 GB STRIX Gaming OC
EVGA G5 750 W 80+ Gold Certified Fully Modular ATX Power Supply
My PC is not detecting my graphics card. I flash the BIOS to 1405. Now it don't recognize my boot Drive anymore and will not boot to Windows screen. BIOS is still not detecting my graphics card. The graphics card lights are all working the fans are spinning, could this be a bad card? I don't know what to do. Any advice would be greatly appreciated! Thank you.
https://linustechtips.com/topic/1151068-gpu-help/
if it's not detecting your card, how could you even flash the bios?
Desktop benching:
https://linustechtips.com/topic/1151068-gpu-help/#findComment-13261578
My board is running built on display, I believe. When I looked at device manager>display adapters it had some random name. I don't remember what it had listed exactly. I'm currently trying to vet windows 10 to boot back on so I can maybe see if it's a driver that I need to install?
https://linustechtips.com/topic/1151068-gpu-help/#findComment-13261582
2 minutes ago, K88 said:
My board is running built on display.
What build on display you are talking about?? Mobos don’t have build in graphics and 3700x don’t have one either. So if you have some sort of display that means your card is working
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1151068-gpu-help/#findComment-13261591
