my gtx 970's clock speeds are stuck at idle regardless of load
 i have tried
reseating the card
updating/rolling back drivers(including a clean install after ddu)
the other pci slot on the motherboard
updated bios/chipset
my system
  • gigabyte b450m ds3h mobo
  • ryzen 3 3200g
  • 16gb teamgroup t-force 3200mhz ddr4 ram
  • 240gb xpg nvme drive
  • gtx 970
  • corsair vs 450 psu
stuff to note
the driver seems to reset as soon as i see the windows login screen
power consumption is also stupid high on idle...
https://linustechtips.com/topic/1150873-issues-with-gtx970/
Have you tried a manual overclock just to force a clock speed change?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1150873-issues-with-gtx970/#findComment-13260141
When did this start happening?
Do you own the gray label VS450 or the orange label one?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1150873-issues-with-gtx970/#findComment-13260175
