So ive had my trusty system for about a year or so, and im finally going to try to upgrade something. Ive thought about upgrading my cpu, but i dont think an cpu upgrade would make any diffrence with the other parts i have, and my low chipset mobo. Ive locked myself on an ram upgrade, since ryzen loves fast ram and the 8gb total i got rn isnt enough. Im currently only playing some modded minecraft, destiny 2, apex, unturned etc. Ive looked around on the used and new market but it seems like there is no diffrence in pricing. A new 16gb 3200mhz set is like 90$ and an used set is like 80$, maybe as low as 70$ but its hard to find. My current PC specs:
Ryzen 3 2200g
2x4gb | 8gb 2133mhz unbranded stuff
xfx rs rx 480 4gb
asrock a320m-hdv r3.0
1tb sata SSD (as400 kingston or something)
https://linustechtips.com/topic/1150869-old-system-upgrades/
Thanks for the quick reply. but i like to buy/order things from known sellers within my country (sweden), so not from like amazon or newegg etc. I found these that are relativly cheap and fast: https://www.inet.se/produkt/5310200/corsair-16gb-2x8gb-ddr4-3000mhz-cl15-vengeance-lpx-svart?utm_source=prisjakt&utm_medium=cpc&utm_campaign=prisjakt
https://linustechtips.com/topic/1150869-old-system-upgrades/#findComment-13260099
Just now, boggy77 said:
but i understand why you wouldn't want to import from the US.
Yeah import charges and who knows what else might happen. Then of course the time it would take to get them. From the link above it would take like 1-2 days, and from amazon like 2 weeks
https://linustechtips.com/topic/1150869-old-system-upgrades/#findComment-13260111
You could use Amazon netherlands https://www.amazon.nl/b?ie=UTF8&node=4550510031
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/1150869-old-system-upgrades/#findComment-13260117
