Did some cable management this weekend and here a before and after picture
Before
After
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/11507-weekend-cable-management-project/
Oooh, looks awesome. Much, much cleaner. How did you find the 600T to use for cable management? Good job :D
600t for cable management .. it is a smallish case for a first build i had a hard time.Not the best for cable management in my opinion but it was my first build so idk about other cases.
Definitely an improvement. Another thing... if you don't plan on using the AC97 front panel header, I'd just cut it off. It's a small detail that would only take a minute or less to accomplish.
Desert Storm PC | Corsair 600T | ASUS Sabertooth 990FX AM3+ | AMD FX-8350 | MSI 7950 TFIII | 16GB Corsair Vengeance 1600 | Seasonic X650W I Samsung 840 series 500GB SSD
Mobile Devices I ASUS Zenbook UX31E I Nexus 7 (2013) I Nexus 5 32GB (red)
Looks decent nice work. Perhaps try some braided extensions for extra cleanness.
I wasn't going to awesomeness in this build i was on a 1600$ budget.If i was not on a budget i would do A LOT more
I Have my main computer in a 600t.  Granted it is modded but i found it to be a breeze for cable management.  Plenty of room in the back, lots of cut outs, lots of anchors for cable ties.  I'm going to be putting together a build log featuring this case soon.  Its a fantastic case if you are willing to play with it a little.
01010010 01101111 01100010  01001101 01100001 01100011 01010010 01100001 01100101
Btw, not to be mean. You miss spelled "Project", not sure if you meant it, Just trying to make sure you know.
P.S - "Projet" thats how you spelled it
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
Great improvement! Nice work.
Gigabyte GA-X58A-UD3R (Rev. 2.0)    Micron C400 256GB SSD     MSI GTX 660 Ti PE OC     Logitech G510
Intel i7 960 @ 4.125GHz                        WD Black 1TB                         Windows 7 Pro 64bit        Logitech G9x
Kingston HyperX 6GB                             Corsair TX850M                     Corsair H50                        Logitech z906
This looks amazing though.
Woops lol
