Help Ram Maxing out.
Go to solution Solved by DarkPhazon,
Breaking News
nvstreamsvc.exe
This guy is the real problem.
I went in and denyed its access and will post when I have this as a solution or not.
Known Issue With Nvidia Gforce Expirience.
https://forums.geforce.com/default/topic/672846/nvstreamsvc-exe-memory-leak/#4140328
Find the svc file and deny all access worked  but you have to re-apply access for any update to work
i5-4430@3ghz
16gb ram
windows 7 professional
Randomly my ram will max to 99-100% and computer becomes useless.
I can't even open window task manager to see who the culpret is.
I have gone thru and updated all drivers and still it happens.
I caught a glimpse of a process starting with ms.......... using lots of ram then black screen.
does anyone have any ideas?
CPU: i5-4430 @ 3.0GHz RAM: 16GB GPU: GTX 670
ASRock Fatality H87 Performance Win 7 Pro
https://linustechtips.com/topic/115049-help-ram-maxing-out/
Dunno, try a malware scan, see if that comes up with anything.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1537941
How often does it happen? And does it happen when you do something in particular on your PC, like open a particular program?
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1537949
mspaint? well mspaint is known for draining quiet a bit of ram, last time I used it at work my computer exploded :/
Maybe try running in safe mode and use task manager to check whether it's a windows process running in bg. Highly doubt it though and also something else worth a shot is to uninstall all the bull crap while you're at it.
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1538002
i5-4430@3ghz
16gb ram
See if it happens with Skype closed. There was a Skype version that did this. If that is it, get new version.
If not? Go to ninite.com grab malware bytes. Let it update. Reboot computer and press f8 to get to safemode. run malware bytes.
If all that fails. Do a system restore. Type system restore in the star bar.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1541299
Do you have anything in msconfig on startup that you don't recognize or looks suspicious? I'd probably begin by unchecking those from the msconfig startup tab that look suspicious or are possibly causing the memory issue, one at a time. Restart after each one you uncheck to see if you can identify the one causing the problem.
*edit:  Also keep in mind that if it is something from the msconfig startup tab, it may not be something obvious.
For example, recently I was getting spinning circles all of the time when I had my laptop out of the office (outside my LAN), and eventually leading to BSOD out of memory.  The cause was an HP printer/scan program that launched at startup.  When it could not find my printers ip address it would continue trying to find it every 3 - 5 seconds... spinning circles, big slow downs, then out of memory.   Once I was on my LAN again and with the printer online, it was fine.  So now I uncheck that program from msconfig startup tab whenever I'm outside my LAN.   So the culprit may be something innocent looking like my hp issue was.  *FYI- my issue was a known hp problem:  http://superuser.com/questions/433891/windows-7-busy-icon-wont-stop-spinning
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1541400
Ok so I have gone thru msconfig and gotten rid of things that I don't need and or are suspect and will see if that is the issue.
I will post again in a day or two either way the problem splits.
Thank You to everyone who has helped.
I talked with the it tech that built my pc and he thinks its a ram cleaner needed or malware scan or spyware issue but I will find out and keep this posted asap.
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1542208
Do you have a page file, if not turn it on and see if that alleviates the problem.
You say "windows 7 professional" you don't state is it 32/64bit??
Have you checked what starts up when windows loads, it could be something there.??
Go to programs and features and delete anything that you don't recognize. (Don't delete stuff like Asmedia / windows / Microsoft realtek. Just Google anything if unsure.)
CORSAIR RIPPER: AMD 3970X - 3080TI & 2080TI - 64GB Ram - 2.5TB NVME SSD's - 35" G-Sync 120hz 1440P
MFB (Mining/Folding/Boinc): AMD 1600 - 3080 & 1080Ti - 16GB Ram - 240GB SSD
Dell OPTIPLEX:  Intel i5 6500 - 8GB Ram - 256GB SSD
PC & CONSOLE GAMER
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1542396
MsMpEng.exe
This is the program that is messing with my computer.
It is also skrewing with the hdd rates and making it work hard as well
Ideas other than to kill antivirus
64bit
windows defender says its not on and when I click to turn it on it does nothing
Microsoft Security Essentials is limited to 50% at 5am it went into its resource over consumtion at midnight
FIXED!
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1549557
  • 2 weeks later...
Breaking News
nvstreamsvc.exe
https://linustechtips.com/topic/115049-help-ram-maxing-out/#findComment-1606184
