Hi , i need help with overclocking , in bios i put XMP overclock and my CPU went from 3.5GHz to 3.9GHz , and my RAM from 2400 MHz to 3000 MHz , i did test for 10 min with FurMark for CPU and the highest temperature i have is 60°C .
So , is it good or should i stay to base clock ????
This is my PC :
ᴄᴘᴜ⇨ Intel® Core™ i5-6600K ,3.9GHz, 6MB Cache, 14 nm, FCLGA1151
ɢᴘᴜ ⇨ MSI GeForce GTX 1660 Ti Gaming X 6G GDDR6
ʀᴀᴍ ⇨ Ballistix Sport LT 16 GB, 2 x 8GB, DDR4,3000 MHz
ᴍᴏᴛʜᴇʀʙᴏᴀʀᴅ ⇨ ASUS Z170-P LGA1151
ᴘᴏᴡᴇʀ sᴜᴘᴘʟʏ ⇨ Corsair TX650M "650 W",80 Plus Gold EU.
ᴄᴏᴏʟᴇʀ ғᴏʀ ᴘʀᴏᴄᴇssᴏʀ ⇨ be quiet! PURE ROCK SLIM
sᴛᴏʀᴀɢᴇ ᴍᴇᴍᴏʀʏ 1# ⇨ Kingston SSD A400 - 120GB
sᴛᴏʀᴀɢᴇ ᴍᴇᴍᴏʀʏ 2# ⇨ HDD WD Blue 1 TB, 7200 RPM, SATA 6 GB/s, 64 MB Cache, 3.5"
sᴛᴏʀᴀɢᴇ ᴍᴇᴍᴏʀʏ 3# ⇨ HDD WD Black 1 TB,7200 RPM, SATA 6 GB/s, 64 MB Cache, 3.5"
ᴄᴀsᴇ ⇨ Aerocool Aero-300
https://linustechtips.com/topic/1150199-hican-someone-help-with-overclock/
3 minutes ago, Fiveros said:
but how i can know if my CPU won't die in a year of use ? :D
what's your core voltage?
Primary PC:
PSU tier list
How many watts do I need?
1 minute ago, yaboistar said:
i have had a 4790k sitting at 4.7GHz, screaming along at the max safe voltage for three years. it will be fine.
quad cores are still perfectly usable in gaming - productivity is a no on them.
i am not using only for gaming this pc , i am using it for 3d graphic render and  more
1.200 V
That's pretty low, don't worry about affecting lifespan.
Primary PC:
PSU tier list
